how to simulate "expect" and do scripting on com port data?
send "this", expect "that", if true, do "the other" I initialize com ports and want to parse the stream, like EC2.0N+B1=ffff+ of nonsense chars, and have an array to lookup what to do upon exact literal char string.
I know my char end character, "+" but all strings are of different length. if it sees a "B1" and "=" then the next 4 chars must be converted ascii to hex and displayed on this box over here, (which I already labelled)
its simple using tcl/tk and expect, but I have no clue how this gets done using labview, even tho I took a course in this before.
looking at the help and texts, it seems almost impossible, but that cant be the case?
I can output text using concatenate st
ring with a CR+LF, wiring that to my "port write vi" inside some sequence structure...
but taking 115K streaming data from the com port and parsing it? im lost, help!
(2,910 Views)
Use Visa read serial and set the termination charachter to "+". Put this is a while loop. when visa sees the + it will return all charachters before this. Take the last 4 characters of the retured string and do whatever parsing you need to do. The loop will repeat. You set the stop loop condition. Either a button you press or a byte count (115K) or both or something else. Make sure the buffer is big enough to gather incoming bytes while you are parsing string. This really shouldn't be a problem though with the comparable speed of the serial port to the microprocessor.
You could either parse the returned string like stated above, or match on the "=" and take all after the match. Converion from hex ascii to readable ascii is as simple as wiring to a text box. To c
onvert bytes like 'ff' to some decimal value, there are hex string to decimal conversion vi's. All the tools are there, I promise.
Jared
(2,910 Views)
