how to skip 3 chars when use "scanf from string" by the parameter "format string" ?
hi, I want to read a num 123 from the string like that "sfg123" "fgd123" "ghj123"
I know that I can use "%3s" to skip 3 chars, but it will add an output to "scanf from string"
So, how to use parameter "format string" not only to skip 3 chars, but also add no output to the "scanf from string"
(4,115 Views)
Scan from string has an input name "initial scan location". Wire a diagram constant of 3 to it.
(4,101 Views)
it does work
but I want to know is there any special method through the parameter "format string" to skip 3 chars, just like "*" "?" "." "$"
(4,030 Views)
Accepted by topic author chenyin
Hi Chenyin,
Try this VI....
I think... This is what you are expecting....
<<Kudos are welcome>>
(4,022 Views)
What is wrong with having the extra string output on the Scan from String function?  You don't have to do anything with it, and in your picture you are not.
(4,008 Views)
I just want to know is there any special method to reach the same results. What you said is OK.
(3,978 Views)
