how to solve a one dimension thermal diffusion equation
hi
i am new to these forums and new to labview.
please see if you can help me with this -
i am taking 8 sets of data - over 2 minutes - sampled at one second apart. The 8 data points are along 8 equidistand points of a rod and the data itself is the temparature, recorded as a voltage (v) by the thermistor
The data satisfies the following equation -
d^2v/dx^2 = k d^2v/dt^2
that is the one dimensional laplacian of the voltage = k times the 2nd time derivative of the voltage
how to solve the equation in labview !!??
Message 1 of 9
(4,186 Views)
Open the example finder and look at the example "PDE Thermal distribution.vi".
It solves your problem in two dimensions, so all you need is to simplify it to one dimension. 😄
See how far you get.....
Message 2 of 9
(4,178 Views)
hi
i have looked under sxamples but i cant find "PDE thermal distribution" - could you please tell me where it is.
yes but if it is solved in 2d then it cant be too tough to rip the 1D from it
Message 3 of 9
(4,176 Views)
A few options:
  • Search for "PDE", that should narrow it down to a few.
  • Browse by task...new examples for LabVIEW 2009...
  • browse by directory structure...math...pde.llb
What is your LabVIEW version. If it is older than 2009, you won't have it.
Message 4 of 9
(4,174 Views)
fount it...now lets see
Message 5 of 9
(4,173 Views)
to make it 1d -
in the main panel -
i set y value =0 and y range =0 (whats the difference anyway). Cant i get rid of the Y altogether
i can change the cases in the block diagram panel, to 1D, but i have to know whcih type of 1D we are doing - if initial data is taken by a sensor and fed to ELVIs and then stored in array then is the initial and boundary condition "numeric" or "VI"
Also i do not need any plots or graphs- just need to solve the eq to get the K
thanks a lot
Message 6 of 9
(4,165 Views)
any other tips or advice
Message 7 of 9
(4,140 Views)
Here there is what you need for 3d 2d or 1d problems. That's a heat diffusion simulator
http://cfdosc.wordpress.com/2013/07/05/tutorial-for-friendly-user-unterface-edna-screenshots/
good luck
Message 8 of 9
(4,013 Views)
I think the OP was looking for a LabVIEW based solution, though.
Message 9 of 9
(4,005 Views)
