how to start designing filters in labview?
Also...Please post your code. If you have posted some code then your problems started I am quite sure your problems would have been solved. We can not guess your problems.
Besides which, my opinion is that Express VIs Carthage must be destroyed deleted
(Sorry no Labview "brag list" so far)
Message 11 of 15
(762 Views)
the hardware used is a sound card for input signal. what i meant from "output signal in micro volts" that the input signal is in mili volts ok.
I have to filter out the noise and at the same time, i have to amplify the signal also,so that from mili volts,it comes to  few volts...by mistake i wrote it wrong,earlier.
Message 12 of 15
(758 Views)
And what about your code digu. Why is it so hard for you to post some sample of your code ?
Message 13 of 15
(756 Views)
i dnt have any code dear....m trying to do it graphically,by modifying the examples given in labview...
Message 14 of 15
(753 Views)
By code I mean labview code. Send us your most up to date vi file 😉
Message 15 of 15
(746 Views)
