how to stop count as a peak until the pulse fall below a threshold?
sometimes the noise is high, peak detector count more than one peak on a pulse when is it above the threshold, how to set a lower threshold than only when the pulse falls below that, the detector starts to count another peak.
(1,893 Views)
Hi frogliang,
why don't you reduce the noise?
And why don't you attach a VI with some meaningful default data? (Or atleast an image of your signal to explain what you are talking about?)
(1,885 Views)
