how to stop ok button in dialog box
I am using Message dialog box to display message to the user. when I run software it will show Message box but after click on OK it should disappear but  it is still showing. How to close that message box after click on OK
Message 1 of 13
(6,089 Views)
If you'd like some help, you should post some VI's.  We can't tell you how to fix something if you don't show us what is wrong.
Message 2 of 13
(6,073 Views)
here is vi please find the attachment
Message 3 of 13
(6,060 Views)
What about your other code that calls the Express VI?
I'm guessing you're either stuck in a loop or you're using the dreaded Run Continuously button.
Message 4 of 13
(6,042 Views)
I can show this much only is there any way to close dialog after click on ok. by attcahing ok wire to stop or else?
Message 5 of 13
(6,032 Views)
Hi kiwagh,
when you click OK the messagebox will be closed. You need to avoid calling the expressVI again and again in a loop!
When you don't show more you your code (or the whole VI) you need to debug on your own!
Message 6 of 13
(6,024 Views)
Ok I got it. Then please tell me how to stop loop after click on OK?
Message 7 of 13
(6,016 Views)
Yes. Without seeing it, I can't tell you much about how to do it. Wiring the ok wire to the stop terminal of your while loop will do it. It will probably also crash your program in ways you don't want it to.
The default behavior of your Express VI is to disappear when you click ok. If it is remaining, it is because you're launching it again.
EDIT: Gerd got in his reply while I was typing this one up.
Message 8 of 13
(6,013 Views)
Hi kiwagh,
I guess the very basic LabVIEW examples for beginners also show how to stop a loop.
Did you take all those free courses?
Message 9 of 13
(6,005 Views)
Sorry, here is whole data diagram
Message 10 of 13
(6,000 Views)
