how to stop sub vi while loop
hi,
      i have three while loop.
        1)main vi out side of event structure with timeout
        2)second while 1sec time delay
        3).sub vi 3sec delay
all while stop one globle bool controll button.
when i will stop this main vi it will take some time to stop.bcaz delay in while how sop immediate.pls tell me any other methode.
(4,385 Views)
Use a state machine. Have the state machine keep running with a small execution timing (e.g. 10ms) and keep checking if the 3s has elapsed (to do your process) or if it's time to exit.
(blog)
(4,348 Views)
Hi Gokul,
try using Queues.
Attached a sample ,on how Queues used to stops parrallel loops.
In ur case u can pass the Q refnum to sub Vi and stop all the loops.Dont forgot to close refum after while loop.
Refer https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000000YGxRCAW&l=en-US
(4,328 Views)
HI,
        I want blink two LED.
        1).while two LED 1sec
         2).sub vi while LED 3sec
if i will use state machine  both led blink 4sec.
(4,325 Views)
hi,
         led mean two boolean indicator blink...for difference while loop and difference time delay.if i will use state machine totall delay is added.so pls tell me to stop without delay while loop.
(4,234 Views)
Show your latest attempt with using the state machine.
It sounds like you are wiring things up to work in series rather than parallel.
(4,212 Views)
