how to stop until generate a whole cycle waveform when click stop button
Hello dgql!
I apologize for the delay, I'm still looking into the best way to write zero at the end of your code - I will let you know as soon as I have more information. Are you still having issue with your code?
Will Hilzinger | Switch Product Support Engineer | National Instruments
Message 11 of 16
(684 Views)
Yes, I still can not return to the original place when I stop. I am looking forward to your suggestion 🙂
Message 12 of 16
(679 Views)
Thanks for the update - I will let you know as soon as I have more information, hopefully early next week.
Message 13 of 16
(674 Views)
Hello, dgql!
I was able to get my hands on some hardware and try it out myself. I modified the example "Cont Gen Voltage Wfm-Int Clk.vi" (found in LabVIEW under Help>>Find Examples>>Analog Generation>>Voltage). An image of the modified code is attached.
Basically, the modifcation creates a new task, which finishes by writing a zero to the device. This will ensure that your device is not outputting a high voltage when restarting your task.
You can compare to the original example to see the changes made - please let me know if you have any questions!
Message 14 of 16
(665 Views)
Thank you so much!!!
Message 15 of 16
(656 Views)
No problem!
Message 16 of 16
(645 Views)
