how to store a 1D array in column format
hi..i am new user of labview..my Q is how to write  1D array in column format?? i am using write to spread sheet VI..attached the screen shot..
i have used and removed  the \t demiliter and also used and removed transpose option..answers arr very much appriciated..thanks
Message 1 of 11
(5,202 Views)
If you need to write 1D array in column format into the file just use "\n" or "\r\n"as a delimiter in write to spread sheet File function.
-Kumar.B
Message 2 of 11
(5,190 Views)
Simply set transpose to TRUE on "Write to Spreadsheet file.vi".
See below:
Message 3 of 11
(5,175 Views)
Hi Ray..thanks for the help..now i am getting similar kind of error but again, its related to 1-D array..
the error is attached in pics..i appriciate the ur kind help..thanks...
Message 4 of 11
(5,091 Views)
You have to understand the data types(Array and Cluster). The subvi power's output is cluster datatype... The output you connected is array.
So you cannot connect...
Message 5 of 11
(5,081 Views)
thanks..i understand..now, how to write the cluster data in excel?? which option i have to choose......
Message 6 of 11
(5,079 Views)
I saw your code.
Only 3 cluster elements are there inside. So you have to unbundle it. using property node you can convert it into string and built as a array send it to the spreadsheet.
Message 7 of 11
(5,075 Views)
I post one simple vi. Try it. It is not a ideal way. so many ways are there.
For cluster. i use multiple data type cluster.
Check it out...
Message 8 of 11
(5,060 Views)
thank you for ur kind help and time..much appricated...
Message 9 of 11
(5,058 Views)
.vi is not opening..i am having 8.2 and the vi is written in version 9..:(..
Message 10 of 11
(5,055 Views)
