how to store multi iteration plot and plotting all in the end
dear sir / madam
i tried alot but no proper solution i get  but it is quite simple but i dont get it.
need help
i am working on oscilloscope from where i get different signals i do 30 sweeps  and want to draw all signals at the end of the task
(2,736 Views)
Graph 1 shows each sweep as it occurs.  If you remove Graph 2 from inside the loop and attach it to the Shift Register on the output side, when the loop exits (meaning you've collected all the Graphs), the output will plot all of them.  I believe I showed this to you on an earlier post ...
Bob Schor
(2,698 Views)
here i tried it to solve please have a look
i tried it alot i know this is simple but my mind is stuck in it
(2,665 Views)
