how to switch On and Switch Off LED using the Lab view
Then you would connect a boolean control like a switch or button to the input of the DAQ Assistant.
I would recommend you learn more about LabVIEW from here. How to Learn LV
Message 21 of 23
(3,257 Views)
Currently I am using labview to test out a led to turn on and off. (It is a external led using the hardware)
I am using module NI 9263 but I have some difficulty getting it done.
Can you please help me I have no idea where the fault is.
Am I doing it correctly?
It is not working..
Am I suppose to add more things?
Regards
Christopher
Message 22 of 23
(3,254 Views)
I have no idea unless you post your actual VI's.
The problem with using Express VI's is that the real heart of the code is all buried in the background.  Without a real VI to open up and inspect, we have no idea what is going on.
How is it not working?  Are you getting any errors?
Message Edited by Ravens Fan on 06-29-2009 11:07 PM
Message 23 of 23
(3,250 Views)
