how to sync NI 8451 with NI 9172
Hi I have seen this tutorial:
http://zone.ni.com/devzone/cda/tut/p/id/12493
is there anyway you can do this with a NI8451 and 9172?if yes how?
Thanks in advance.
(2,638 Views)
Accepted by Merd
Merd,
This is Kyle M from NI, and I think I actually talked to you on the phone today regarding this issue. Synchronizing an I2C Bus with a DAQ device would be a pretty complex task, with really complex triggering. A far easier route would be to take an analog gyro and read it in with the rest of your signals on a C-DAQ Chassis, as we discussed. That would allow you much tighter timing synchronization, as well as a far simpler and more robust setup.
Kyle M.
Applications Engineering
(2,608 Views)
Kyle,
Yes we did talk together, thank you very much for your help.
(2,594 Views)
Kyle,
How could this be accomplished?  I have a need for this because I require data from a digital accelerometer and analog strain gages at the same time.  The digital accel is connected to the 8451 SPI interface and the analog strain gages are connected to the 9172.  I do not have the option of using analog accelerometers due to size constraints.  Any insight would be appreciated.  Thanks.
(2,559 Views)
