how to take a time window from an ongoing signal
Hello
I need to know how to extract  a (500mstime window from an ongoing signal transfered by serial RS232 to labview. Extracting this time window should occure after 300ms of an action belongs to one frame of a stacked sequence.
Is it a must for doing this to work in the real time environment ?
if you know how to do this just tell me ,please .
thanks for beaing concerned.
(3,920 Views)
Why use such a font? Do you mean you want to extract data from graph for a specific time period? If so can you post the data? Are you acquiring the data?
(3,910 Views)
The point is how exact do you need the timing?
Dealing with OS async signals like the serial port (with internal buffers and interups) is not very precise for timing. I have about 5 ms to 16ms jitter in mind .... however this was about 10years ago and we switched to dedicated hardware then. (a µC that read @ 9600 and send the data with timestamp over USB) Search for CAN bus analysers, this hardware is build for such proposes, maybe NI have it and it will run without RT.
Give it a try: write a routine that read single (or n)  characters from the port and feed them with a timestamp into a queue. make this routine high priority and turn of debugging ( vi properties), in the OS disable or minimize the serial input chip buffer (the build in 16,32,64,... byte) so interupts where faster generated.
Now analyse your known test data in a consumer loop.
And please stop shouting 😛
Greetings from Germany
Henrik
LV since v3.1
(3,896 Views)
sorry, I did not mean to shout . I just wanted the the font to be easier to be read.
I am acquiring EEG signal using serial port. I have an array of boleen LEDs in which every LED has a letter written on it . These LEDs light up in a certain sequence . The user should concentrate on one letter written on one LED to write it with his thoughts . lighting the intended letter is a visual stimuli that generates an unordinary signal called p3 . This signal appears after 300 ms of the occurence of the stimuli .So, I need to extract the segment between 150 and 600 ms after every LED lights up .Then I will use these segments to train a machine learning technique called "support vector machine " to distiguish the p3 from the ordinarry signals . and then perform some way to identify the intended LED ,and so the corresponding letter.
I hope that I could clear what I wanted this time.
Any ideas ? Thank you .
(3,866 Views)
You've posted this in three different threads. This one here, this one, and this one.
Please pick one thread so all of the information is in one place.
(3,862 Views)
Please stick to a single thread. And after you have decided on the thread put continued here and link it to the thread that you have choosen. Just to reuce confusion and get a better response....:smileywink:
(3,831 Views)
The challenge I see is the correct timing and syncing:
I assume you have a EEG hardware with a fixed samplerate and it's data is send via RS232 to the PC running LV. This is done with timer/clock X.
LEDs etc are controlled via LV with timer/clock Y.
Both clocks run slightly different, so after 30min you might be of for some ms... .
You don't have a spare EEG channel for a sync signal?  Maybe just adding a LED abused as a lightsensor (smal currentsource) on top of one channel to add a sync spike ?
Henrik
LV since v3.1
(3,820 Views)
