how to take analog output through pci card 6014?
Hi ritesh,
do you mind to rephrase your question without creating links in the message body?
What have you tried so far? Which problems occur? Any error messages?
You should be fine using one of the DAQmx AnalogOutput example VIs from ExampleFinder…
(3,637 Views)
Hi GerdW,
Thanks for replying. I am using pci card 6014 with connector board CB-68LP. i am getting the analog output when i am using my own code from pin 22 of CB -68LP, but i am not getting the analog output when i am using DAQmx AnalogOutput example VIs from ExampleFinder, though the code is running perfectly.
best regards
ritesh
(3,603 Views)
Hi ritesh,
which examples are you talking about?
Which output channel does the example use?
Did you check other "pins" as well?
Are there really no error messages?
(3,594 Views)
Hi
the example uses ao0 pin and the code is running smoothly. i am not getting any error message . the only thing is that i am not getting the output from any of the pin.
(3,583 Views)
HI ritesh,
did you try to use AO1 instead?
(3,552 Views)
yes but i didn't get anything.
(3,542 Views)
