how to test the PCI/PXI 4461
when i receive a new card, how to test it?
when i click the "self-test" in the Measurement & Automation Explorer,it shows that "the device has passed the self-test."
is that means the card is ok?
or i should make other test to confirm?what test should i do?
(2,597 Views)
You can also use the test panels in MAX to test each channel of input or output after they are terminated. This is a good verification that your signal conditioning, wiring, etc is working as expected before getting LV involved.
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(2,596 Views)
