how to test the low level duration time ?
see attached vi, i want to test the low level duration time, how to do that ? thanks for help !
(2,923 Views)
Hi ateprojec…,
your vi is not executable for me! To measure the time you can use the "Tick Count (ms)" function.
[edit] ok, i think it´s not the time you want. Smiley Happy Can you explain a little bit about what you mean? [/edit]
Hope it helps.
Mike
Message Edited by MikeS81 on 06-17-2008 09:13 AM
(2,922 Views)
sorry maybe your not understand what i want. Here is the picture, i want to get the duration time that voltage is about 0 v. see attached. thanks
(2,915 Views)
Hi ateprojec…,
you can convert your data to waveform and search for values less than one. Count theme and multiply the number with dt, this should be the time you need.
Mike
(2,910 Views)
