how to track line using webcam vision and move along it
Hi everyone,
I have a question which I can't really find any topic about it.
Currently, I had made my rover robot to be control wirelessly using a 3-Axis joystick and working perfectly.
But I would like to add some features to the vision system on board the rover.
I am trying to make the webcam to detect black line against white background and then it will just autonomously move along the the black line.
The thing is I only know abit about vision setup.. So if any one out there able to guide me along the way?
Do I use colour pattern matching or colour matching or pattern match?
How to I make sure the black line stays in the middle of the vision?(Eg. moving itself to centre the line within its vision)
How do I control the motors using the vision aquired from the above?
Message Edited by Shinra on 08-23-2009 10:06 PM
(3,264 Views)
Accepted by topic author Shinra
Hey,
To your questions:
Pattern Matching or Color Pattern Matching would be to slow.
I would use a Simple 1D Edge detection which returns the coordinates and angle of the edge.
You have to control your motors that e.g. the angle is 0 or 90 degrees (depending on your coordinate system) all the time.
The manual of this robot should tell you how to control the motors.
Hope this helps,
Christian
(3,242 Views)
