how to transfer 2d array between LV Call Lib Func Node and a DLL?
the document only lists the 1d array data transfer, is it possible to trans
2d array btw LV and DLL ?
any sample or rules ?
thanks
(2,716 Views)
Depends what you understand under a 2D array. In C a two dimensional array will sometimes be a pointer to an array of pointers to the array of data. This is not how LabVIEW can pass 2D arrays. LabVIEW 2D arrays are really just a pointer to a single array with row * column elements.
Rolf Kalbermatter
Rolf Kalbermatter  My Blog
(2,716 Views)
Hi Richard,
I have attached an example that uses a dll built in LabVIEW and calls it from LabVIEW. Please take a look at how the Call Library Function is configured.
I hope this helps.
Sincerely,
Feroz
(2,716 Views)
