how to transfer to executable file
I have a Vi and I want to transfer in into a executable files because I am quite new in labview and I don't know how to do it?
thanks
(3,023 Views)
If you want to build a executable from your VI you can do this with the application builder. This is, however, not a part of every LV package.
(3,016 Views)
Hi
If you don’t have LabVIEW Pro you cant make Executables.
I don’t know if  you have sat the LabVIEW basics courses or have the manuals if you do have a look at LabVIEW basics II chapter 6 this will take you through it. If you haven’t then I have added a link with some tutorials that should help.
www.zone.ni.com/devzone/conceptd.nsf/webmain/5adbc06ac32e508a8625706e0062ebd1
If you are new to using LabVIEW and you think you are going to be using it a lot I would suggest coming on some of the courses especially LabVIEW basics I and II.
Hope this help
Any further problems drop use another message.
Tim M
NI UK
(2,994 Views)
thanks, I know how to do it now
(2,988 Views)
