how to transfer waveform graph to array
we are using sound card as a AD converter. using the example Simultaneous Sound IO.vi provided by Labview, we get the waveform of the two channels. Now we want to analyze the signals by using FFT. So we need to save the waveform to 2 arrays, which should include time and amplitude info. How to do that?
Thanks a lot!
(2,757 Views)
You have a couple of choices. You can use the FFT function in the Analyze >> Waveform Measurements pallette or you can use the Get Waveform Components function from the Waveform pallete. To create the time array you just build it knowing t0, dt, and the length of the amplitude array.
Tim
(2,757 Views)
This is exactly what I would have suggested. Please see my attached VI for an example of implementing these suggestions.
Hope this helps!
Liz F.
(2,757 Views)
