how to turn 12 LED on
lets say i have 12 LED for 12 hour indication.
one LED should on for one hour and next led for next hour say like
LED_1 should remain on from 8am to 9am
LED_2 should remain on from 9am to 10am and so on.
i can make this but to compare each time stamp for each hour. its so big coding.
please tell how to do with other way like using loop.
(3,224 Views)
You can use a quotient and remainder for this. If you use the time as x, and 12 as y, you'll get 0-11 as remainder. If you put the 12 LEDs in an array, you can simply replace that index in an array of false booleans with a true.
(3,215 Views)
Use the Seconds To Date/Time and then unbundle the hour.  From there you can just use a constant of 12 FALSEs and Replace Array Subset to put the TRUE where it needs to go.
(3,214 Views)
Seconds to Date\Time has the benefit that it returns he local hour. But you still get 0-23. So use a q&r with a 12 to get 0-11.
(3,209 Views)
sorry difficult to understand for me.  😞
can you please write code?
thanks
(3,197 Views)
We are not here to do your homework.  We gave you step-by-step instructions.  Give it a try.  When you run into issues, post your code and tell us what is stopping you.
(3,188 Views)
