how to turn off a LED in an array
hi
I have an array of LED, i need to turn the LED OFF(as per the case).
Message 1 of 36
(4,614 Views)
Hi Veeru,
use the "Replace Array Subset" function to do it.
Mike
Message 2 of 36
(4,607 Views)
Thanks Mike
Yes its true,i forgot that
Message 3 of 36
(4,604 Views)
Do you have a means to index which element that you want to turn OFF?
EDIT: Mike was faster than me..  😉
R
Message Edited by JoeLabView on 07-08-2008 10:29 AM
Message 4 of 36
(4,599 Views)
Thanks Joe and Mike
I using the colour box,the LED turns on with some different colours depending on the conidtion.I tried using the replace subset,its turning OFF all the LEDs.
Message 5 of 36
(4,579 Views)
Please post your code so we can see what you are doing wrong.  It sounds like you are replacing the whole array rather than just the particular element.
Message 6 of 36
(4,571 Views)
Thanks Ravens
i Want to do,when deactivate button is pressed,the corresponding LED turns oFF
Message 7 of 36
(4,563 Views)
You cannot "turn off" a color box. You could just assign it a more neutral color. 😄
Message 8 of 36
(4,548 Views)
Thanks altenbach,
Thanks for the reply for the other post,i will check it and let u know how it goes
Message 9 of 36
(4,540 Views)
Besides, you're using shift registers to hold the LED states and the disabled items, but in the event that handles the "Deactivate" buttons you're not updating those shift registers. You're generating another array that goes into another tunnel output that goes nowhere.
Message 10 of 36
(4,537 Views)
