how to uninstall LabView when it's not in Add/Remove list
That's all fine and good, but what do I do when there is no National Instruments section in add/remove programs?
Mike...
Certified LabVIEW Architect
LabVIEW Champion
Message 11 of 15
(2,865 Views)
Hi MikePorter,
Try going to C:\Program Files\National Instruments\Shared\NIUninstaller, where C is the drive in which you installed the software. Then you can use the NI Uninstaller.
Kaitlin N.
Message 12 of 15
(2,832 Views)
Of the course that assumes you have the aforementioned directory - which I do not.
Mike...
LabVIEW Champion
Message 13 of 15
(2,828 Views)
NI can not be found in the Add/Remove. How to remove? Thks so much
@Kaitlin-N wrote:
Hi USman ASghar,
National Instruments does not recommend the use of msiblast to remove NI software. While it can help you easily uninstall our software it can also leave some unwanted files as well as delete more files than necessary. It can also change registry keys in your computer and cause further problems. We recommend the traditional method of using Add/Remove programs to uninstall our software.
Message 14 of 15
(1,940 Views)
Thanhlm
With a fourm post this old it is best to start a fresh thread considering much has changed in the last two years on where LabVIEW's program files reside on yopur computer.
Good Luck
Message 15 of 15
(1,918 Views)
