how to update the 2011 FRC version of labview to 2013 or 2014 if available
where can i find the 2013 or 2014 update for the 2014 FRC labview. After installing the 2014 labview software, whien you run the program it says it is running on the 2011 version which is normal, but i am trying to review last years programs it will not open the VI's because it says that the program i have is a later version then the file, which is correct, so how do i or where do i go to update my labview to the current version?
thank you, ashley
(2,712 Views)
You can find the FRC 2014 Software Here: (including the update suite)
https://decibel.ni.com/content/docs/DOC-34731
You should be able to open VIs written with a previous version of the software with a later version. For example, You can open a VI written in LabVIEW 2011 using LabVIEW 2013. You should be able to open LabVIEW 2013 and open the code that you guys wrote last year. I was a little confused from your description. Is this what you are tried?
(2,649 Views)
