how to use Curve Fiiting Express VI
hi,
Iam a new bee to LabView.
I want to use Curve Fiiting Express VI from (Anaylse>> Mathematics>>
Curve Fitting >> Curve Fitting). to get the best fit.
The actual formula is : I(L, λ) = Isp(λ)/G(λ) { exp [G(λ) · L ]
− 1}
where L is stripe Lenght
I is intensity
lamda is wave lenght
G is the net gain
given the values of L and I for respective lamda i have to find out the
net gain (g) by from the above formula.
the formula which i am using for non linear model is :
x/g*(exp(g*l)-1). is this formula right with respect to the above
formula. or shall i change it and i dont know how to use the Curve
Fitting Express VI, I will be very much thankful for any kind of
advice.
thank you.
(4,050 Views)
Altenbach started to answer your question in what I am assuming is your other post.
If you can answer a few of his questions we should all be able to help you get to the solution you need.
Evan
(4,045 Views)
Hi evan, thank you for your reply.
I(L, λ) = Isp(λ)/G(λ) { exp [G(λ) · L ] − 1}
above formula is taken form Variable Stripe lenght method.
actually i have a very little idea about the formula.
my boss says Isp can be taken as a constant.
G is the net gain (Fitting parameter).
I is the intensity
L is the stripe lenght
i dont know what shall be the independent variable.
my task is related to spectrometer. using a labview vi, i get the data from the ccd camera and store it in a file.
please see the attachment to see how the data looks like
i have to find out netgain(G) using the above data. taking the G values i have to plot a graph. showing the net gain.
i am un aware weather this can be done using Curve fitting express.vi or shall i derive a formula for G.
if u can give any idea about this problem or show me some way, i will be very much thankfull to you.
bye.
(4,023 Views)
I is the intensity
bye.
(4,017 Views)
I think I might see what you are trying to do.  You have I and L and you want to solve for G.  Is that correct?  You can certainly use the Curve Fitting Express VI.  If you place the VI down, you can select to have a non-linear fit.  This will put the fitted parameters into something that is very close to what you have for your equation (ie y=a*exp(b*x)+c).  Once you have the parameters all set up you can wire your data to the VI.  If I understand the formula correctly the b coefficient will be your Net Gain for that lambda (you can group your formula into the above equation where a=Isp/G, b=G, and c=-Isp/G).
Hope this helps!
Andy F.
(4,001 Views)
hi andy,
thanks alot for the reply, it helped me. but still need to examine the wether the results are right. how ever thanks again for your valuable help.
bye.
(3,983 Views)
