how to use NI 9265 and NI 9263
Hello!
I'm using NI 9263 to genrat voltage  and NI9265  for current, can you tel me please what is the format of value to be set to generate correspending current for the first module and voltage ( positive and negative ) for the second one.
I can't generat negative voltage with NI 9263 module
I can't generat any current with NI 9265 module
I'm working withe veristand 2011 and the value of curent and voltage is sent on packet
regards
(3,150 Views)
Are you using LabVIEW within Veristand?  If not, you probably should post on the Veristand forum: http://forums.ni.com/t5/NI-VeriStand/bd-p/440
"There is a God shaped vacuum in the heart of every man which cannot be filled by any created thing, but only by God, the Creator, made known through Jesus." - Blaise Pascal
(3,143 Views)
Yes I m using labview FPGA
(3,139 Views)
Hi rbi1,
Thank you for using National Instruments discussion forum!
I think we have not enough information in order to help you. How do you communicate with your modules? Are you using a LabVIEW VI? if so, are you using scan engine or FPGA mode? and if not, are you working directly on the target in VeriStand, perhaps by using default CompactRIO configuration when adding a new FPGA configuration?
Thank you in advance,
(3,109 Views)
