how to use Video Blaster WebCam Go in labview
Hi
is there a way i can access Video Blaster WebCam Go directly from labview ??? and how
thanx
(3,478 Views)
We do not provide drivers to interface with webcams, but there are several third party toolkits that allow you to access webcams from LabVIEW. Please refer to the post by Enrique in the following thread to get the links for those toolkits: Capture images in labview using wireless webcam (D-Link DCS-1000W).
Or if there is an ActiveX interface or DLLs available to control your webcam, then you can call them from LabVIEW. The ActiveX functions are located at All Functions->Communication->ActiveX palette, and you can call DLL functions using the Call Library Function Node from All Functions->Advanced palette.
Good luck with your application!
Shakhina P.
(3,457 Views)
Hey - I know for a fact that there is a NI project that allows access to a webcam for IMAQ applications. This software saved us so much for development of a simple part presence detector.
you can get the software here http://digital.ni.com/public.nsf/allkb/274A74A901399D0486256F32007295F9
(3,452 Views)
thanx alot
i did it with imaq for usb
but there is a little problem
capturing image is done by running the vi
how can i make labview waiting until i press abutton on the camera then labview automaticly take the picture??
thanx
(3,446 Views)
hmmm,
OK - most of the cameras have software that when you press the button the image gets saved into a directory.
you would need to have labview watch that directory-when a new image comes in then you process it and remove the original
my logitech webcams saves the image to mydocuments/mypictures/logitechpictures
(3,428 Views)
could you also use imaq to scan the live video for the event to happen then cature a frame?
(3,426 Views)
thank you
but isn't there any activex that can do it??
(3,423 Views)
