how to use a globale variable to get the value of a local variable used in other VI
I use Labview in my final project study. I need to save the contents of local variables in a SubVI obtained for use in another VI. I assembled these data in a cluster and I thought to use a global variable that Continet these data to be updates every time the VI is executed.
How can I make it through the global variable?
thank you for yor help:)
(3,434 Views)
I think you can use functional global variables for that purpose. Functional global variables are VIs that use loops with uninitialized shift registers to hold global data.
Check whether it meets your requirement.
______________________________________________
Kudos are welcome
(3,420 Views)
where can i find these Functional global variables? i don't find it in my labview
(3,410 Views)
Try these examples: https://decibel.ni.com/content/docs/DOC-20897
https://decibel.ni.com/content/docs/DOC-21226
Also search on ni.com for more results.
CLA CTAChampionI'm attending the GLA Summit!
Subscribe to the Test Automation user group: UK Test Automation Group
(3,406 Views)
FGV is a VI which you need to implement and call it when ever required. You will not find it in functional palette.
Kudos are welcome
(3,403 Views)
Why not connect the cluster to an output and wire it through?
/Y
Qestit Systems
Certified-LabVIEW-Developer
(3,394 Views)
Itried to connect a cluster in the input of my global variable but it doesn't work.
But i found a solution with the FGV and it seems to be a good one 🙂
thanks
(3,354 Views)
