how to use boolean push button as a constant to add to other values
KP2,
The run continuous button is only intended to help in debugging subVI's, is should not be used in normal operation.
When you have a program that needs to repeat, you need to use a while loop, like Paul shows in his example.
Message 11 of 12
(595 Views)
Thanks so much for everyones help.
Kevin
Message 12 of 12
(583 Views)
