how to use http post to send command to the java scripted web
I want to send a command to a browser controlled local device through http post.
by using http get, i can get the information from local device without problem.
however by using http post , the local device seem get the request because I get 200OK code from post header. but the local device can not response the command that i send through post buffer.
I talked with the vendor who wrote the javascript, he said it looks like that the command send to the device, however, the post string i sent can not interpreted by the device.
It could be syntax error.
But what I send through post is the exact the same I found in the web debug tool.
Anyone can help?
(2,291 Views)
Also I am still using labview 2013, which is quite old, while I use  iwebbrowser2 to open the web in labview will show script error. I think it is because the default browser engineer is too old and can not support the web i open. but I am not sure whether it will affect the http post too.
(2,290 Views)
And this is the string I send through the post buffer:
the vendor ask me to change the parvalue for "parindex":98," every time use the post, and I did it ,but dose not help.
par: {"params":{"iFielbusControl":{"parindex":85,"parmin":"-","parmax":"-","parvalue":0,"parname":"FielbusControl","partype":"int","parfact":"1"},"iPanelControl":{"parindex":86,"parmin":"-","parmax":"-","parvalue":0,"parname":"PanelControl","partype":"int","parfact":"1"},"iPanelPowerCommand":{"parindex":87,"parmin":"0","parmax":"10","parvalue":0,"parname":"PanelPowerCommand","partype":"int","parfact":"1"},"iPanelPowerCommand2":{"parindex":88,"parmin":"0","parmax":"3","parvalue":0,"parname":"PanelPowerCommand2","partype":"int","parfact":"1"},"iPanelFaultReset":{"parindex":89,"parmin":"0","parmax":"65535","parvalue":0,"parname":"PanelFaultReset","partype":"int","parfact":"1"},"iPanelLaserOn":{"parindex":90,"parmin":"0","parmax":"3559","parvalue":0,"parname":"PanelLaserOn","partype":"int","parfact":"1"},"iPanelBeamOn":{"parindex":91,"parmin":"-","parmax":"-","parvalue":0,"parname":"PanelBeamOn","partype":"int","parfact":"1"},"iPanelPointerEnable":{"parindex":92,"parmin":"0","parmax":"1000","parvalue":0,"parname":"PanelPointerEnable","partype":"int","parfact":"1"},"iPARVALUE_CMD":{"parindex":93,"parmin":"0","parmax":"1","parvalue":50,"parname":"PARVALUE","partype":"int","parfact":"1"},"iPARID_CMD":{"parindex":94,"parmin":"1","parmax":"100","parvalue":48,"parname":"PARID","partype":"int","parfact":"1"},"iNODEID_CMD":{"parindex":95,"parmin":"-","parmax":"-","parvalue":0,"parname":"NODEID","partype":"int","parfact":"1"},"iWRITE":{"parindex":96,"parmin":"-","parmax":"-","parvalue":1,"parname":"WRITE","partype":"int","parfact":"1"},"ipar97":{"parindex":97,"parmin":"0","parmax":"65535","parvalue":0,"parname":"par97","partype":"int","parfact":"1"},"icount_new":{"parindex":98,"parmin":"0","parmax":"1000","parvalue":996,"parname":"count_new","partype":"int","parfact":"1"},"ichecksum_download":{"parindex":99,"parmin":"0","parmax":"65535","parvalue":0,"parname":"checksum_download","partype":"int","parfact":"1"}}}
(2,285 Views)
anyone can help?
(2,212 Views)
