how to use labview 8.6 to perform AC and
Hi there,
I am first time using the labview (version 8.6) and need to write a program to perform AC and DC testing for my ADC chip, can anyone please help me with this. Many thanks!
Hardware i am using and specifications.
ADC chip :ADC0808CCN (Data sheet in attachment)
DAQ Card : NI-PCI-6024E
Testing include: DC testing - Offset Error, Gain Error, INL and DNL.
                        AC testing - conversion time and full BW tests.
I really need help.
(2,781 Views)
The 6024E provides you Analog Ins/Outs, Digital Ins/Outs and Coutners. In LabVIEW they will be programmed using the DAQmx driver functions. There are lots of examples provided for each of the components of the card.
Since you also do timing measurements I'm not sure if this device is capable to fill your needs. I would suggest to contact your local NI Office to see if that might be possible or you would need something different.
Christian
(2,762 Views)
Please don't duplicade post.
Please refer to your original post in http://forums.ni.com/ni/board/message?board.id=380&message.id=1810
(2,739 Views)
