how to use polynomial equation for scaling
Hello ,
I am using LabVIEW 2013 version.
I have a sensor to acquire pressure. Pressure sensor gives out 4 to 20mA current output corresponding to pressure . This is a linear conversion.
I am using DAQmx Scale VI (linear) before I configure the channel. So automatically I get the scaled converted output on DAQmx Read VI.
But I have another force sensor. It s conversion equation is y= ax (cube) + bx( sqaure) +cx+d .
3rd order polynomial equation. y will be force output and x will be current read from sensor and a,b,c,d are co-efficients.
How to do this with Create Scale VI.
I tried  but there is forward , reverse co-efficients. to be used.  I require help on this as to how to implement my  scaling.
(4,138 Views)
Did you look at the 'help' for the DAQmx Create Scale VI?
Creates a custom scale that uses an nth order polynomial equation. NI-DAQmx requires both a polynomial to convert pre-scaled values to scaled values (forward) and a polynomial to convert scaled values to pre-scaled values (reverse). If you only know one set of coefficients, use the DAQmx Compute Reverse Polynomial Coefficients VI to generate the other set.
(blog)
(4,124 Views)
You can also scale it yourself by reading in the current and using basic math operations from the numeric pallete
(4,069 Views)
