how to use stop sign function for execuation abortion
I tried to use a stop sign function to abort an execution. Just exited the program when I clicked a stop button that is linked to the stop sign, as if clicking the Abort execution on the toolbax.  It seems a very straightforward task, but the stop sign does not work as expected.
I am new to LabVIEW programming.
I attach my file for your checking, and hope you can catch some errors I committed.
Thanks !
(3,293 Views)
Globally, I don't think using the "STOP" VI is a good practice. When you need to stop a VI, it generally come down to ending loop early. For the "for" loop, you should use a right click on it, and clic on "show condition terminal" (I'm not sure it's the exact name in English) and use that to stop your VI. You can also use a while loop.
I joined a simple example, with both the for and while loops.
(3,282 Views)
You're using the "Run Continuously" button, aren't you?  Use a proper loop, instead.  That button is only for troubleshooting and experimentation.  Actually, I wish it would just go away.  It mostly just gets newbie LabVIEW programmers into trouble.
Including me, when I was but a young pup.  😉
Bill
CLD
(Mid-Level minion.)
(3,233 Views)
