how to use t-shark (wireshark ) using lab view??
i want to use tshark using labview to extract RTCP sender and reciever reports and put them into strings so i can log and graph the Delay and jitter and loss packets by the time
iam using windows Xp
Pleaaase help
(5,167 Views)
Are you wanting to post-process a log file created by WireShark, or are you wanting to perform live processing of data recorded by WireShark?  Your request/question is unclear...what specific questions do you have about doing this?
-Bob
(5,159 Views)
my project is about Voice over ip
so iam going to sniff the network to extract RTCP and put the results in labview ,i guess there is a way to do that from labview since tshark can be run from the command line  so system excuter in labview will do ... the thing i don't know is i got ip headers sniffed how can i put that into strings and and decode them using laview in order to plot them in a graph ??
(5,155 Views)
You can either setup wireshark to log that traffic and post process the log file or you will have to interface to the WinPCap driver that Wireshark is using to sniff the network traffic. There has been some work done to interface to WinPCap here in the past but the project has to my knowledge never gone to a fully fledged state, so I would expect you to have to do some work on that level too.
Rolf Kalbermatter  My Blog
(5,133 Views)
If you're getting the IP headers through as strings or IP addresses LabVIEW offers 2 functions to convert String to IP, IP to String under Data Communication > Protocols > TCP in the block diagram.
(5,121 Views)
thanks all
i got another question : how can i import text files from a specific directory and in specific order and in case i had this file before just ignore it and go to the next file ?
thanks
(5,028 Views)
check the software tab at ControlSAG company, www.controlsag.ro. A libray for network sniffing and network parameters checks is provided.
(4,846 Views)
