how to use table as indicator and control
i need to display data from a file in table and the table will allow the user to modify this data and then save the new values introduced in the table in a file. How we can do that?
(3,444 Views)
tllotca,
Part of your question is dependent upon the format that the file is in. Once you read in your data, you will need to use a property node to place that data into a table conrtol (not indicator). I would then have a "SAVE" button, that when pressed, saves the data in the table back to the file.
Randy Hoskin
http://www.ni.com/ask
(3,444 Views)
@Randy_H ha escrito:
tllotca,
Randy Hoskin
@Randy Hoskin, thank you very much for your idea, it worked perfectly for my project.
(2,942 Views)
