how to use two kinects to capture different pictures and display the picture simultaneously in the same front panel?
Hi, I want to use two XBOX 360 kinect to monitor different tasks and capture the picture and display them in the same front panel. How can I achive this in labview? Thanks in advance.
(2,528 Views)
How are you currently connected to just one Kinect? Is it with one of the methods mentioned in this thread?:
http://forums.ni.com/t5/LabVIEW/How-to-Connect-the-Kinect-to-Labview/td-p/1450358
(2,473 Views)
You should install the Microsoft SDK driver and the kinesthesia toolkit, there are some examples can help you.
(2,465 Views)
Will that help you to use LabVIEW?
(2,458 Views)
