how to view control logic from a vi file
Hello there,
I'm new to Labview and I have a very large vi file which contains control logic for a wind tunnel. I'm coming from a FORTRAN programming back ground and used to reading codes in text line format. Is there a command in Labview to view the coding in text line format?
Thanks in advance
Regards
CJ3134
(2,572 Views)
Hi CJ,
no.
(LabVIEW is all about dataflow-based graphical programing.)
(2,560 Views)
What kind of "control logic" would a text printout of a Fortran program show you?
It is a lot easier to follow control logic in LabVIEW's graphical format than it is looking at lines of text code!
(2,531 Views)
