how to write 2D array row to database?
Hi all,
I have the element. My code should identify the particular row in 2D array in which that element matches & write that entire row to database.
I do not know to create databases in LV. Please guide over the problem.
Thank you,
Vaibhav Gandhi
B.E. Instrumentation & Control,
INDIA
(2,947 Views)
You can create the database anyway you see fit, e.g. in SQL server. Then use LV to connect and just read and write data.
If you want to handle all of the database ideas through LV you'll first need Database Toolkit or similar. There's Create Table, Drop table, Insert data into table and ofcourse Select data which'll give you the tools you need.
In order to write your entire row to database, you can either build a SQL string yourself and Execute Query or build a cluster of the row and feed that to Insert Data.
/Y
Qestit Systems
Certified-LabVIEW-Developer
(2,932 Views)
