how to write 2d array into 2d array of cluster of 2 elements
i want to write 2D array and a string into 2D array of cluster having two different element. one element is numeric for 2d array and other element for string. please help me out this problem
(2,971 Views)
Accepted by topic author R.V.
you can do it as follows. A Vi with the control is also herewith attached.
And regarding insertion of a numeric and string into the 2d array, I dont think you can do that. An array can use only one data type. you may use clusters for holding different datatypes.
Nitzz
(Give Kudos to good Answers and Mark it as a Solution if your problem is Solved;))
(2,966 Views)
