how to write a cell value to one Cell in one table Indictor of front panel in LV6.1?
i tried with Property Node, but i failed.Hope for your helps!
(3,052 Views)
A table is basically a 2D string array. Just use Replace Array Subset.
___________________
Try to take over the world!
(3,051 Views)
You can also use an INVOKE node (set cell value). That's sometimes more convenient, specially went you want to modify the column or row headers.
CC
Chilly Charly    (aka CC)
(3,043 Views)
thanks a lot! It is OK
(3,020 Views)
helllo CC:
How to modify the column or row headers? I just can modify the cell value , because the min X index and Y index is both 0, what is the index for the column or row headers? Thanks!
(3,017 Views)
@shenzhengpib wrote:
helllo CC:
Use -1 as index value
CC
(3,012 Views)
