how to write and 1D array of clusters to a text file?
I have an 1D array of clusters (consists of Text, double and booleans), which I would like to be written to a text file.
This will form the test.
What is the easiest way of doing this?
(5,866 Views)
Hi
Find the attached vi.
WriteFile_LV82.vi is designed using LabVIEW 8.2
WriteFile_LV80.vi is designed using LabVIEW 8.0
Sowjanya
(5,857 Views)
You should also check out the variant configuration VIs in the OpenG site.
___________________
Try to take over the world!
(5,847 Views)
Definitely would have been my first suggestion.
My second suggestion: You can wire the cluster directly to the "Flatten to XML" function in the string palette and then feed the output of that to a Write Text File function.
(5,838 Views)
