how to write data to an existing database table in sql using array in lab view
i am trying to write the data in an existing table in sql databse.but i dont know how to get it done .plz help me
(4,048 Views)
What have you tried? Post your vi and explain your issues.
/Y
Qestit Systems
Certified-LabVIEW-Developer
(4,016 Views)
i trying to add a new item in my table named Screws in database .when i run this it shows error.help me solving it out.
(4,002 Views)
Accepted by topic author parii
The error text is clear: The number of columns doesn't match the data provided. Your Insert data only has 3 columns, how many are named in the Columns control?
It'd be easier if you attached the VI's with the controls set to the current values as Default.
/Y
Qestit Systems
(3,976 Views)
THANK YOU
(3,941 Views)
