how to write excel file
hi i am new here.does any1 know how to write excel files???like giving some examples or tutorial on how to write basics excel files?? thank lots!!
(3,755 Views)
In "Find examples" you will find "Write Table to Excel", and other vi's.
(3,747 Views)
If you don't already have the report generation toolkit then you might want to check into purchasing it.  Otherwise you can use the Write to Spreadsheet VI to generate a spreadsheet file.  Do follow JohnBoy's advice by looking in the Example Finder which you can access on the LabVIEW splashscreen or by going to Help>Find Examples.
Eric A.
Distributed I/O Product Support Engineer
(3,723 Views)
Additionnaly, if you just need to create a file that will be opened (and processed) later with Excel, you can simply create a standard ASCII (text) file and append the .xls extension to its name (instead of the usual .txt extension). This is enough to make it appear as an Excel document.
Chilly Charly    (aka CC)
(3,694 Views)
