how to write multiple inputs into 1 file + how to use PWM
hi,
I wanna take analog inputs from 2 channels, then write them into a single file, have them the data plotted on 1 graph.  how can I do that?
also, I wanna output 2 PWM signal lines after some calculations with the data of those 2 channels.  how can I do it?
another thing:
can I use Labview to make a state-obersver program?
the board I am using has part number:  183554C-01.  it is a DAQ Signal Acessory.
(3,001 Views)
hope this helps:
Harold Timmis
htimmis@fit.edu
Orlando,Fl
*Kudos always welcome:)
(3,000 Views)
