how to write to an array intermittently?
Imagine in a conventional program like C, you have initialized k = 0, and then entered a while loop. Inside the loop you have a line like:
if(condition) {k=k+1; array[k] = expression;}
How do I do the equivalent in LabVIEW?
The actual LAbVIEW operation I am trying to do is to record a reading every time the user presses a button in a non-time dependent application.
Thanks.
(3,058 Views)
take a look at the code I attached to this post.
Maybe it will help you a bit.
Stephan
(3,058 Views)
That seems to sort the issue.
Kind Regards
LouisP
NI-UK
(3,058 Views)
