how to zip a string
   LabVIEW now has zip functions built in, allowing you to zip to a file.  But what if you want to compress a string for other use-cases?  Why can't we have a simple zip-a-string function?  For example, you might want to compress a string before transmitting it over a relatively slow buss.
DaveT
David Thomson Original Code Consulting
www.originalcode.com
National Instruments Alliance Program Member
Certified LabVIEW Architect
Certified Embedded Systems Developer
There are 10 kinds of people: those who understand binary, and those who don't.
(3,907 Views)
It would appear to me, that if one is building a custom protocol as referenced in the example, one could develop protocols that were more efficient that zipping ever thought about being.  Honestly, I cannot think of a compelling reason to do that except to transmit verbatim data, in which case, you could write to a zip file, read it into a string and transmit... a work around to be sure, but gets it done.
Paul
(3,900 Views)
If you don't mind using .NET, this might help:
GZIP compress/uncompress of string using .NET
(3,866 Views)
OpenG has a Compress string function.
Ton
Message Edited by TCPlomp on 14-04-2010 01:31 PM
My LabVIEW Ideas
(3,853 Views)
