how we can convert an array into .csv format and save it in .txt file or excel file?
Accepted by topic author Bill El Sayed
First of all,
Post the question or the query in the body of the forum not in the heading itself.
You can use the "Array to spreadsheet string " found in the the "programming->Strings" pallete with the required delimiter to convert an array. Then write them to a .txt or excel file
Guru
Regards
Guru (CLA)
(6,011 Views)
Or, you could just use Write to Spreadsheet File. Wire your array directly to it, and it will write out a text file with delimited column. CSV uses a comma to separate column, so if you just specify a comma as your delimiter you'll get a CSV file. These file can be directly opened in Excel without having to resort to ActiveX to create actual Excel workbooks.
(5,969 Views)
Thanks very much! it's running!
(5,953 Views)
