howto delete point from a citadel trace ?
I want to delete or modify some points from a citadel trace.
Is it possible ?
thank you
Gianpiero
(2,847 Views)
I believe the DSC module historical database protects the records from being altered or modified. You can make SQL queries to view the data, but you cannot change the data. To answer your question, you can delete a trace if you want to but cannot modify the points if the data has already been logged.
Adnan Zafar
Certified LabVIEW Architect
Coleman Technologies
(2,838 Views)
I will copy all the datas to a new trace avoiding the time interval where are the points to be deleted, delete the old trace and rename the new.
This should do the trick.
thanks
Gianpiero
(2,830 Views)
