hp34970a无法被MAX识别出来,我用的是Agilent的GPIB-USB连接线
上位机软件平台是Labview7.0,按照其要求装了 FlexMotion 4.5;IVI Engine 1.52;NI-488.2 1.0 for USB-A;NI-DAQ 6.5, 6.6, 6.7; NI-IMAQ 2.2; ValueMotion 4.3
hp34970相关的驱动安装的是Agilent IO Libraries Suite 14.2版本
但是多方试验和努力还是无法在MAX中找到设备
刚开始弄Labview相关的东西,比较菜,在NI论坛也搜了很多相关资料,但是没有找到问题解决方法,客服也没有说出所以然,麻烦哪位有经验的给点指点,先谢谢了。
(4,172 Views)
English Translation
I use Agilent's USB-GPIB adapter.
The PC software platform is running Labview7.0.  Installed are FlexMotion 4.5; IVI Engine 1.52; NI-488.2 1.0 for USB-A; NI-DAQ 6.5, 6.6, 6.7; NI-IMAQ 2.2; ValueMotion 4.3
The HP34970A has the related drivers installed from Agilent IO Libraries Suite version 14.2
After many efforts to test, the device still cannot be found using MAX
I searched the NI Forum for related issues with Labview.  Found a lot of relevant information, but did not find a solution to the problem.
First that you for helping with this issue.
(4,156 Views)
I have no idea if the op will understand this but a few things in his post do not make any sense. First is the mention of NI-488.2 1.0. There is no such version and no NI 488 driver should be used for an Agilent controller. Drivers for the HP34970 are not at all relevent. Neither is the FlexMotion, ValueMotion, or IMAQ. Lastly, it would be really nice if the poster mentioned what solutions were tried so someone here does not recomend the same thing. Usually, by having the Agilent VISA and NI-VISA installed, you can go into MAX and enable tulip support.
(4,148 Views)
 您不必使用NI - 488驱动器与控制器安捷伦。安捷伦有其自己的驱动程序。
眼前的问题不在于HP34970司机, FlexMotion , ValueMotion ,或IMAQ 。
你尝试过什么为了解决这个问题?
当你有两个“安捷伦签证”和“的NI -签证”安装。打开了MAX (测量和自动化资源管理器)软件。选择能够支持。 = “称为”郁金香“
(4,130 Views)
