html file cannot open by IE
hi,
I had created my report using html library from the function palette. I can open the file and see the image correctly only on those PCs on my programming PC. However I cannot see the image on those new PCs using the IE. All PCs have the same version. I cannot open the "x" with  right click also. Any idea what is missing here?
I have attached the file for your reference.
Appreciate any help.
Shin Seong
(2,706 Views)
Shin,
i think you didn't attach the file due to the preview button which removes the file....
Nevertheless, if you create an html-report, you should get more than only one html-file. There should be a subfolder in the directory where the html-file is located which has the same name as the html-file. Within this folder, you should find all screenshots you need for the report.
hope this helps,
Norbert
Norbert
Expert: Geometry
(2,703 Views)
